- May 26, 2001
This dash assembly was removed from a GN that the owner wants to convert back to an original, stock GN.
It is wired and has the connector plug for an analog GN or T-Type dash. All that is needed is the proper senders for VDO gauges.
It was working fine in the GN, and the wiring is a very professional job which alone would take MANY hours to accomplish.
The price is only $900 plus shipping, and the dash bezel will be included, and you can use your clear plastic cover.
Gauges are tach, speedo, oil, water, boost and fuel.
