'nothin special.
How common are these? i cant tell if that was sarcasm or not.
The offset numbers to look for are: -15 and -23
That means they are gnx rims if they have those offsets?
and these are pretty much identical to gnx wheels correct?
SignUp Now!'nothin special.
Ok so basically run fronts on rear and rear on front with3/8ths spacer.
didnt real gta wheels come only in 1 color goldGNX rims and GTA (Pontiac Trans Am GTA) rims share a similar look. Both are 16" rims. The GTA rims came in several styles (dimpled and non dimpled) and colors depending on year and color of the TA. The GNX rims were GNX specific with an offset only for the GNX. They are RARE and EXPENSIVE. No one to my knowlege makes repops. The GTA rim on the other hand is repoped and remanufactured. I think a set is about $800. The offset of the GTA rim is not perfect for the G bodys. The front GTA rims have a better offset and many use 4 fronts. A set of fronts and backs can be used with a spacer on the back. Kirban sells the spacer. GTA rims are popular to give a GN a GNX look but since 16" tires are now not too popular people are using other rims.
There is a thread somewhere here that has picture and specifications of the GNX rims vs the GTA. There are many other threads about the GTA rims and how to refinish them which yours need. Do a search.:wink:
