Reginald West
Senior Member
- May 25, 2001
Ok here is a good one.
I have put a FAST B2B unit on Dads T Type.
We had a batch fire DFI on the car prior to this. The DFI jumped the MAP sensor signal wire to the stock MAF sensor for a signal. Here is the problem.
The FAST unit is reading voltage to the MAP sensor but it is not getting a signal. We used Caspers stock harness adaptor to plug and play the MAP sensor.
I have the gray wire from the MAP sensor in hand. I need to know where to splice this back to in order to get the signal to the FAST unit.
Help
There are 2 gray wires in the bundle so I would be guessing which is the right one.
Help
