SignUp Now!Nice job, post pics as u goDecided to go intercooled for the better flowing intake and throttle response
Modded the upper plenum to keep the ta33 in the stock location
Can u post a few more pictures?got my curiosity peaked.Decided to go intercooled for the better flowing intake and throttle response
Will post more on the goCan u post a few more pictures?got my curiosity peaked.
Hey will the iac work from my hot air throttle body on the 87 throttle body?Brad_H You won't regret it.. Even if you don't use a intercooler, you improve throttle response and flow... I actually got a better idle. BTW, do not forget to change the two wires on the TPS (top wire to bottom wire and bottom wire to top wire. Leave the middle wire). Post pix on your conversion..
Hey man do I route my vacuum lines like the 86/87 vacuum diagram?Maybe 6 to go may chime in... I use all 86/87 parts when I did mine.
