Going intercooled
Brad_H
Decided to go intercooled for the better flowing intake and throttle response
Modded the upper plenum to keep the ta33 in the stock location
Brad_H You won't regret it.. Even if you don't use a intercooler, you improve throttle response and flow... I actually got a better idle. BTW, do not forget to change the two wires on the TPS (top wire to bottom wire and bottom wire to top wire. Leave the middle wire). Post pix on your conversion..
Can u post a few more pictures?got my curiosity peaked.
Turbo oil return mod.....had a couple of hot air oil return lines kicking around, rubber hose and clamps to tie them together
Hey will the iac work from my hot air throttle body on the 87 throttle body?
Ready to install intake manifold
My 84 iac housing fit my 62mm 87 throttle body and the gaskets are the same for the housing. I wonder if it will run bad with the 84 iac sensor?
Just about done
Man just got an 85 and was thinking just to leave it stock .but now I don't know . cWMCCRY you used the turbo also from 86-87 what else? Also the intake bolts right up?
You can use your stock turbo, but you will top out real quick. You can pick up a ta49 reasonable or 86 turbo. Once you have converted, turbo selection become easier. Just know anything bigger than a ta49 will require a 2800 stall.
I might do this one day but im on e85 so maybe i dont need to.
Anyone have a 87 throttle cable and throttle cable bracket( the one that bolts on doghouse)....i posted in the parts wanted section, just raising my odds .
Ps. Needs to be shipped to Canada, Ontario
