MNcarbturbo
What's Fuel Injection?
- Mar 9, 2009
Before I want to mess around with the boost I was wanting to find a decent way of monitoring whats going on. Ive basically narrowed it down to 3 options
A. Air/Fuel ratio guage. Be nice to see if im running ritch or lean when I turn up the boost. Could be done with a EGT probe, but it isnt as responsive
B. A knock guage. From what ive understood, I would need a 83-87 knock sensor, Turbo 83 ECM, and a Caspers 10 LED guage. Would be the best option, but the hardest and most expensive. The knock sensor is easy enough to get but the ECM would be a pain to find, then wire. Not to mention if it would even work not being hooked up to a dizzy and carb. Be a great option if I had an 83 car or had the parts, but I have nothing for it. Not a huge fan of it too because it detects false knock, which is more to worry about.
C. EGT probe. My least favorite option. Slow to respond, doesnt tell you a whole lot but its cheap. A A/F ratio does the same thing but tells you more.
My favorite option out there is a A/F guage. Where do you put it into the intake at? Im not familiar with them at all. Is it like a water temp probe? Any good brands?
