SignUp Now!Just the stock ecm, i want to run the engine with no knock about 15 psi boost. I dont think that the ecm and knock system are working correctly even at stock levels. There has to be something better to control spark and and other situtions. Also the qudrajet is junk and would like to install a holley or something. I got the boost reference stuff down pat also. Basically i dont want this motor ending up like the last one, cracked pistons becouse the stock system was not doing it's job.What op system are you using now Jim?
The early systems have a little different set up than the puter operated ones Dan. I believe Rich's site has the diagrams and failing that I think I've got them saved. The ESC is the turbo control center.Just to clarify, you still use the ESC when you use the MSD 6A and BTM? Any special issues setting it up?
Thanks.
You need to do a write up on it Aj. That would help a great deal for us and the 301 guys.The BTM will work great with the ESC system, but it does require a special diode or it acts funny.
if you are good with wiring and can source a 1227165 ecm you can run it SD spark only or injected at anything upto 30psi using the software we created and use down here http://delcohacking.net/forums/viewtopic.php?f=27&t=356 allows for realtime tuning of spark and/or fuel knock retard control and has added extra outputs for meth spray boost control etc.
i run a lot of carberated dirt track cars spark only with it and many N/A v6 buicks with turbos bolted on![]()
