SignUp Now!Originally posted by Randy Greenoe
Make SURE you clean or replace the oil feed line as well! If there is any dirt or crap in there it will take out turbo in record time. Yep I learned the hard way!![]()
Originally posted by ViciousV6
That Turbosaver you're purchasing will replace the oil feed line.
Originally posted by wlaukaitis
www.johnsperformance.com Go to "Engine Parts", it is $46.00.
He has a nice braided one. It is a little tricky to get in. I made sure the ends swiveled before I put it in. I attached the turbo flange first and then screwed it into the block and the attatched the flange to the turbo, I used telfon on both sides. Oh, I have a stock turbo and it was out before I screwed the tube into the block. The gasket it comes with is fairly think so you might want to get slightly longer bolts (about 1/4 inch or so, you can cut longer ones if you like)
It is a nice piece! You wont be disappointed!!
He has some other nice stuff too, like the control arm bushing heat shield!
Originally posted by salvageV6
Studs are a great idea.
And it bends fine to line up.
Works well on both my cars, very difficult to install without 8mm studs in the turbo however.
