Several options. The cheapest is get a couple of weld on brackets from a dirt track supplier and use the same front calipers you have. The discs can be gotten off the 4th gen camaro. If you have to have a parking brake you can use calipers off a 3rd gen camaro. Another option is to cut the backing plate mount and fit the 4th gen set up. Effective and cheap but somewhat labor intensive.
