Well fellas I goofed up,I got all educated up on doing my valve springs ,bought the kirban springs and tools and tore into the passenger side ,I hooked up my compression testor hooked up the hose with 130 psi on the line holding fine.I broke the 90Degree end of the bar that came with kirban rocker arm on the first valve and got past that by using the 45 degree end.All was looking great ,fished my first set of keepers with my new magnet then the valve slowly drifted outta sight.it was like a bad dream,it drifted right into the head.I unhooked everything and realized I did not take the schrader valve outta the compression testor.I did not have any rope so you know the rest.Luckily it was on the exhaust valve at the front of the motor.I think I can pull the header and maybe fish in there and push the valve back up through the exhaust port.Think it will work?since I gotta pull all this stuff off I guess I might as well do the timing chain and oil pump,since I am that far I guess I might as well pull the pan and do the front and rear main seals...hell I might as well pull the motor and freshen the whole thing up....if I would have only taken the schrader valve out. honey I need more money....
