TT/Ameasap
The White Blur
- Jan 31, 2002
Yes, you will get an effect of about 1/2 the advertised jet rating.
scott wile
So, this is with a dry system?
I wouldn't even think about trying to spray alcohol through your turbo. It wouldn't make it through the intercooler very well. Oh...nevermind I just saw that you are a hotair car...It might work out well for you then. I would be wary of it still...liquids are bad about puddling, but maybe the turbo would keep it moving the right direction![]()
Nitrous, when it comes out of the noids/lines turns into gas lickety split. It would make it through the IC because it would just move with the pressurized charge. However if you do that you are going to lose some of the effect because it's moving a really long way and it's going through a very warm intercooler, which is going to heat up the nitrous. You also wouldn't want to try a wet shot through a turbo on an intercooled car. You would have a really tremendous backfire and immediate problems.
I spray mine in the up pipe about 6 inches away from the tb. I ran a 75 shot single NX nozzle and it hit like Mike Tyson with the boost coming on. I can't imagine how violent Don's must be. Mine went from 23 psi to about 28 psi on the spray up high. 35 makes a very noticeable difference as well, I picked up 8mph in the 1/8th on a 35!!!
If you have money or can fab, do a direct port. If not, IMO single wet nozzle is super easy and very affordable.
Disclaimer: I am not a nitrous expert, but I have sprayed pretty much every car that I have owned except for a few crappy beaters (and I thought about hosing them too). I just am using my experience and some common sense![]()
Ok, I was thinking there was such a small amout of fuel on a 35 shot that it would be vaporized by the time it entered the turbo;However, I wasnt thinking about the bigger jets that may be added in the future. Makes sense now
Im thinking of spraying before the alky, but still in the uppipe. Seems like location is solidified now, on to the wiring
How are these units being activated? MAP sensor, TPS, ??
