Got-em 3 Stg. 2 "s
SPEEDSTAR
I just got 3 stg.2"s.............153 ON/C....4 CROSSBOLTS EACH SIDE 4.030 bore, SLEEVE IN #2,,,,NEEDLE CAM BEARINGS
..........153 ON/C ...NO CROSS BOLTS , OIL PROVISION UP FRONT..4 BOLT CENTER MAINS.......4.O20 bore , REG. CAM BEARINGS
...........153 ON /C FRONT / REAR CROSS BOLTS......4.020 bore, REG. CAM BEARINGS
..1 BILLET CRANKS 3.590 STD. STD.
2 MOTORSPORT CRANKS 3.590 STD,STD.
1 SET CARILLO 6.5 RODS
1 SET CARILLO 6.650 RODS
4EA. OLIVER 6.5 RODS
[11 EA.{ NEW }WISECO 4.000 BORE, POLYDYNE COATED PISTONS, 1.400 COMP HEIGHT , .927 PIN, TOP RING .050 , 2ND. RING .0625 , OIL .1875 ]
2 BILLET FRONT COVERS
1 MOD. FRONT COVER
2 BALANCERS, 1 SMALL , 2 MED,w/ INTERUPTER RINGS
2 SETS HEADS
1HEAD
2 SETS V/COVERS
1 SET PONTIAC STYLE VALVE COVERS
2 ROLLER CAMS
2 GEAR DRIVES
2 MSD DISTS.
3 DRY SUMP PANS
1 DRY SUMP PUMP
1 MOUNTING BRACKET FOR DRY SUMP PUMP
2 SETS TD ROCKERS
3 INTAKE MANIFOLDS
2 SETS GILMOR CRANK DRIVE PULLYS
1 GILMOR PULLEY FOR WATER PUMP
I haven"t decided what I will sell yet , so stay tuned...JEFF;)
