Just bought the car a month ago - It's been sitting since '94 (over 20 years) due to bad Cam Sensor.
Car has 132,xxx original miles on it.When I start it, the oil light comes on and the motor makes some ticking noise (Sound like lifters are not getting oil).The oil which I drained before starting - was very black. I'm not sure if that was from sitting or lack of maintenance. I'm guessing a little of both. Also, the previous owner replaced the timing chain before parking it. I'm planning on pulling the oil pan to check the oil pickup screen and pump (Not sure where the pump is located on these). Should I run some oil flush through it first? Let me know your thoughts. Thanks again for the help.
