gov. spring replacement ?
  • Thread starter Thread starter mark p. liner
  • Start date Start date
M
mark p. liner
Guest
can someone please tell me step by step how to replace the gov. spring. also i need a spring, where can i get one? at the time my gn is the only car that drives,and all the shops want to keep the car a day or so. i cant go a day without my car, i need it to go to work.plus i dont want them to put the wrong spring in it.by the way its a 87' trans. thanks in advance
We now have BRF governor springs.
Let me know your mailing address and I'll get one out to you.
Installing it is a matter of removing your pan and the governor cover. The governor cover is the rearmost aluminum housing inside the pan, held on by four 13mm bolts.
Bruce has a neat way of retaining the spring with a set screw if you are having trouble keeping it in place.
meanbuicks,i e-mailed you my info, and this is the first problem ive had with the spring. hope its the last. thanks alot;)
How much for the governor spring? I would like one too.
Scott
