I have done several searches and have not found the info I need. I am looking for detailed instructions for the set screw modification w/pictures if possible.
I havent had any problems with the spring flying out yet but I do experience WOT shift points being a few hundred RPM too high. I figure the set screw will not only prevent the spring from coming out but should also lower my shift points due to the increased weight.
TIA
TIA
