Hello guys,
Building a 2004r for my '69 chevelle.
What happens if I use an other than orange 11 tooth GN gov gear as far as WOT shift points?
A tooth with more gears (governor driven, speedo drive) would slow down the governor and have higher WOT shifts correct?
However I would need a smaller 10 tooth/29 tooth combo. This would make WOT shifts at a lower rpm correct, due to the governor reaching rpm quicker and centrifuging the weights at a lower engien rpm and output shaft speed....
Running 3.73's and 26" tires. Thanks
