outatime86
- Aug 14, 2018
My governor has a light and a heavy weight. Only one spring though. When I recently disassembled to change my orange gear to a green gear, due to my 373z, I forgot which weight the one spring went on, so I put it on the heavy. Does anyone know?
Went for a drive and she shifts good 1-3, 4th seemed to lag and went high rpm then shifted once I partially let off throttle. I still need a WOT tune so my driving was under light throttle only less then 10psi. Trans temp didnt get above 160 so my cooler n fan are doing their job. Temp sensor is in the pan.
Thanks in advance
Thanks in advance
