turbo39151
anycoloraslongasitsblack
- Nov 7, 2002
TurboDave: I will double check the entire harness just to be safe. Ignition module is bolted down nice and snug.
SignUp Now!when I crank the engine, I get the normal "vroom" of the initial start and then nothing---Whole car rumbles to life- almost...
Do you have a scanmaster or scantool? Whats the coolant temp reading?
Post you all your readings.
1. Checked pwr at A6 and C16 (11.4 and 11.8v respectively)
2. Re-checked scanmaster--- Apparently wasn't getting good connection at ALDL
Numbers are as follows:
AF-05
L8- 08
Bat-11.3
Int-128
BL-128
CLT-64
ATS-66
TPS-.44
IAC-140
MAL-00
3. Tried to "bump" the cam sensor went counter clockwise and back clockwise in small increments. Nothing...
Too tired to look at it anymore tonight.![]()
