TURBOPOWERED68
David
- Jan 31, 2006
Thats why i am taking my AAA card.The beating will stop when the leaking ceases.
SignUp Now!Thats why i am taking my AAA card.The beating will stop when the leaking ceases.
I drive it year round as long as it rained after it snowed, Anyway if its dry out Sunday morning church is in session (Captree state park) the drive is awesome.or just not start it and not worry about it until it's time to bring the car out from hibernation in the spring..
i know it's hard to believe, but millions and millions of cars survive thru cold winters without the benefit of a shelter of any kind..
When my headgaskets were leaking I put "Cadillac tabs" in the radiator. No more leaks. That was five years ago. Your GM dealer sells them.
You better check your block. When water freezes it expands uniformly. The plugs in the block are not there to protect the engine from frozen coolant.Ck your freeze plugs
Mine popped out above the starter
Because I did not add antifreeze
yeaup it peed it self again the night that it went down to 5* So something is definitely wrongwait Dave did you find anything wrong?
I hopeif it hold pressure and doesn't leak when the engine is warm, then it's probably nothing major. just a little shrinkage and/or hose hardening somewhere.
Keep me informed on the track rental dave,I should be in..I drive it year round as long as it rained after it snowed, Anyway if its dry out Sunday morning church is in session (Captree state park) the drive is awesome.
And i am putting together a Track rental for the spring so i have to be ready to run by then.
I did the drive the crap out it test and it passed.
Drove the car for 35 hard miles 2 hours straight boosted to around 22-23 psi. and nothing Radiator and reserve still full, hoses very HOT and very swollen and no leaks. everything cooled down checked the oil and its still clean.
For now i am forgetting about this until i do the pressure test sometime this coming week.
I called Atco 3 times already going to call them again on Tuesday.Keep me informed on the track rental dave,I should be in..![]()
I did and I need your help going to send you a pm later on tonightyou just did a 2 hour pressure test... and it passed...
now start worrying about something important.
