I have been fighting this freaking thing for a while and it seems a lot of other guys are having very similar problems but I have yet to see some good answers to the issue. I have not been able to throw parts at it cause money is real tight plus I don't like buying a part unless I know that is the fix.
I am having the notorious bucking and car nosing over problem that so many others are experiencing. Basically the car is falling on its face and and will not recover unless I lift. It is also 100% boost related because it will only do this at 15 psi and I assume higher obviously cause it wont go past 15psi. This is not an rpm issue because it runs great at any throttle position at any rpm up to 14 psi. So this tells me that the increased pressure in the cylinders is a problem but what is causing it is got me.
Just before this issure arouse I installed a TT chip went to the track made 3 really good passes, came home parked the car and it sat for 2 weeks> when I went to go drive it after sitting I bucked and popped real loud at 10spi and ruptured the fuel return line> I replaced the fuel lines with steel braided lines and an inline filter it has now been doing the below described issue ever since.
Also while very light throttle just cruising I can faintly hear it dropping cylinders every so often which leads me to believe it"s an ignition issue.
I have a Type II coil/module I put new Ac R42 gaped at .030- No fix
I swapped out with a Stock coil and module that I had- same condition.
I swapped out plug wires (not new just spares)- same condition
I removed my crank sensor to inspect, it looks like it has just barely rubbed in the slightest way but I dismissed this as a cause due to the car running great all the way through the rpm band with lower boost.
I have verified my fuel is rising correctly with increased boost, plus when the issue occurs I am getting 780mv to 805mv which tells me it is not lean. I am also showing zero Kr except one time it showed .5
My charging system is working good at 14.5volts at idle and I have a voltage booster and hot wire kit.
I have checked TPS all grounds, cam sensor all wiring and have not found an issue. I unplugged the cam sensor one time and same issue occurs. I unplugged the maf which is an LS1 wit translator to try and drive it and the car shuts off as soon as I unplug it.
The only thing I have not done is buy a new module, coil pack or wires, and I doubt that is the problem because I swapped them with others and the problem did not change the least bit. I don't have a spare ecm so that is a possibility and I don't have a data logger which I am sure would help determine the cause.
If you see anything I have over looked please chime in, this is extremely frustrating and I am just about out of ideas and places to look.
Thank you!
Thank you!
