The springs attach on the bottom of the grill, you will see a notch on each corner of the grill. Put one end of the spring on the notch and pull it forward just about straight ahead and you will "feel" or see a hole in the front bumper where the other end of the spring goes. If the spring does not look right when you connect it, turn the spring around and switch the ends.
