What would cause growl to come from the back of the transmission(2004r)??
Still drives fine, all gears are there, just "growling". Like a bearing is gone maybe??
I put it on jack stands because i was thinking it may have been a u-joint or the rearend, but it's deffinetly in the back end of the transmission. Just spinning the wheels by hand, I can hear it in the back of the transmission.
Or ring gear issue. Sounds like it to me anyway. the ONLY way you are going to KNOW is to pull trans and take apart. Try dropping pan first and see what is in it.
