GSCA email just dropped
sdteb
trying to get it like you
if unplugging the cam sensor while running the car dies...is that a bad cam sensor? or set wrong?
What do you have for scan tool?
Details on the engine and such.
Cold, KOEO readings?
Cold start running and driving scan readings are?
Warm, KOEO readings?
Warmed up, running and driving readings are?
Stock maf? Have you done the tapping on it to see about it? Not fool proof but if it stumbles you know you need deeper thought on it.
stock maf, it doesnt stumble when tapping it....
What do you have for scan tool? scan master
Details on the engine and such. rebuilt by previous owner, nothing crazy, i can take a pic of them, 212 roller
Cold, KOEO readings? ill post the video of the readings
the numbers look good, with the exception of the blm's a little high at idle, 142, driving it cleans up, havent found any vacuum or exhaust leaks to speak of
I think it should stay running. My car died out at a light. Was hard to start. Got it home. Changed every sensor/module except for cam sensor. Turned out to be crank sensor.
