GT35R on a 4.1?
CTX-SLPR
Howdy,
Would a GT35R be a good match for a 4.1 with 8.3:1 compression, 70mm Accufab TB and doghouse, 210/210 billet roller, 1.65 T&D's, 3.42 gears and a TH200-4R? What stall would be best to go with it? I want it to make 450hp at the flywheel on straight 93 and still be able to crank it up to 550 or more on alky.
Thanks,
is the GT61 identical to GT35R with the dual ball bearings and dual GT wheels or does it simply share the same compressor wheel? Any other ideas for the perfect turbo for a 450hp 93 pump gas 4.1 that's deadnuts reliable in a 4000lb car?
