Your internal wastegate might be doing its just, but they arent as good as external gates, plain and simple. Why else would they be used for high horsepower applications and internal gates arent?
Search google for external gates and quicker spool, Im sure you will find something. Search Subaru and Evo forums and you will see its common knowledge, Ive even seen datalogs to show that boost builds quicker. Who to call? Titan Motorsports, AMS, Boost Logic, Full Race... hell, ask Precision Turbo. They will tell you the same thing. Boost builds quicker because internal wastegates dont hold boost as well.
Ive never seen an external gate leak boost like an internal gate. All WGs need some sort of reference as to when they should open, internal or external. Most people buy a boost controller when they have an external gate anyway, why wouldnt you have one?
The answer as to why is because its much easier to setup a closed loop system that uses an external source of pressure to control the gate on an external and the fact that most high hp cars run T6 flanges so they dont have provisions for internal gates. External gates are overcome by backpressure all the time (especially in heads up racing where the turbo is the limiting factor). Thats why they often use external sources of pressure like compressed CO2 to hold it shut. I dont need to search any forums. You just need to post the proof. So far you havent proved $hit. My internal gate hold just fine to 650hp. Above that it needs more spring pressure to prevent it from unseating at high rpm. It doesnt leak at all on spoolup. The actuator arm doesnt even move a kunt hair at 25psi on the t-brake
