GT6152 vs TE45A
I'm torn between these two turbo's. One will be going on a stock long block, PTE stock location intercooler, Motron 60's, MAF Pro car.
It will be a strip street car and will be using a 3200-3400 converter.
Let me know what you guys think.
Doug D
What are your goals?
There is roughly 1/2 sec difference in potential between them IMHO..... but the 6152 will match up better IMHO to your converter......
The 45A probably would like a little more stall.
TE45A will probably need 3400-3600 stall. The 6152 is a good turbo for a stock motored car. If you had heads and cam, you could go TE45A.
Okay makes sense.
Right now the car has a stock longblock, stock intake and TB. I'm going to see how hard the car will run without touching the motor, then go from there.
Doug D
The 6152 will be plenty. Plus it will be more enjoyable to drive on the street than the 45A.
Okay makes sense.
Doug D
The 6152 should go low 11's with pump gas and alky... on a stock motored car.....with a few choice bolt-ons and good traction..... (sub 1.60 60' times) IMHO
Oh... mid 20's on the boost.... 23+ deg timing
You will have to sneak up on the tuneup.... upping boost then watching o2's and knock... until you get there...
That's a good goal to shoot for. I'm going to really start dialing in the car with the MAF Pro and once I get a handle on it, I should be able to get the car to run the numbers.
I've heard alot of good things about the 6152, any other street/strip turbos I should look into?
Thanks guys,
Doug D
Wow, talk about options for one turbo. Inlet/outlet size, A/R, BB Time for more research.
Thanks,
Doug D
Give Jack Cotton a call & i'm sure he will help you pick the right Turbo for your needs. I would go with a ball bearing unit & you won't need as much stall speed in the converter.
