SignUp Now!Street car ? PT67 all the way. A PT76 on a stock cube motor is going to be a slow spooler. After that I like the PT70 GTQ
I would run the 70GTQ over the 71GTQ. I ran the 71GTQ and ran 10.20. I switched over to the 70GTQ and ran in the 9's with less boost then my 10.20 pass with the 71GTQ. If you run more then 30psi the 71 will make more power. Under 30psi the 70GTQ makes more power. That turbo thats on your car has not been fully maxed out yet. Guys have run in the 9's with that turbo already at over 138mph.
