Jul 8, 2002 #1 1 14mins New Member Joined Jun 3, 2002 Messages 105 I am installing some guages, and want to tie into the dimmer switch. What wire and color do i tie into. Thanks
Jul 8, 2002 #2 K KENNE-BILL Member Joined May 24, 2001 Messages 509 Plug into the fuse box at the open terminal labeled lps (lamps).
Jul 8, 2002 #3 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,945 Don't add too many lamps to the dimmer circuit or you will end up with a puddle of smelly plastic. Not exactly sure of the limit of the dimmer depends on bulb wattage, I wouldn't go past 3 or 4 added bulbs.
Jul 9, 2002 #4 1 14mins New Member Joined Jun 3, 2002 Messages 105 Thanks guys. Salvage- I added a turbo boost guage on the pillar, and a oil pressure, volt and coolant temp guages above the glove box in the black plastic. Looks great! Wish i would have started the modds 10 years ago when i bought the car.
