SignUp Now!i had to cut the baffle out of my valve cover due to the harland sharp rockers and now i have quite a bit of oil comming out of my breather, did anyone add a catch can to their setup?
How many breathers do you have on the engine?
And is the oil coming out the little breather on top of the VC?
My TTA had three breathers and no issues. And yes it had those rockers. I just had a small breather on top of the 90 degree rubber elbow.
the engine is a fresh rebuild, and i only have 1 breather on top of the 90 on the drivers side. and thats where the oil is comming from. i also have the stock pcv setup too.
Ding ding ding.. thats your problem. Not enough breather.
Add a breather to both sides, make sure your not pressurizing the intake through the PCV.. your problems will be gone.
so should i dump the pcv system, and add a breather setup to the pass side valve cover?
I didnt say that. I said add two more breathers to the engine.
