just plain john
El Camino a Go-Go!
- Feb 24, 2007
Since it's out anyway, and since a 3" DP is part of the plan, I'm thinking of replacing the stock motor mounts with the H&R poly mounts. This should provide enough clearance for the DP, as well as some peace of mind, but can anyony tell me if false knock is apparent when using them? They are supposed to eliminate the need for a tie down strap, but are they really necessary for a mild street build? OEM mounts are significantly less expensive.
