Dec 10, 2014 #1 R Rob'zride New Member Joined Dec 10, 2014 Messages 4 I have a low mileage GN.The brakes are rock hard.Anyone know where I should look.Thanks for any help you Can give.It is greatly appreaciated.
Dec 10, 2014 #3 T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Messages 14,013 How long has the brake light been on warning you of a problem?
Dec 10, 2014 #4 R Rob'zride New Member Joined Dec 10, 2014 Messages 4 TurboDave said: How long has the brake light been on warning you of a problem? Click to expand... It isn't showing any problem
Dec 10, 2014 #5 R Rob'zride New Member Joined Dec 10, 2014 Messages 4 Anything else I can look four,and thanks for. Help.
Dec 10, 2014 #6 R regan j Active Member Joined Sep 19, 2008 Messages 759 Look above your post at the stickies. One is titled Powermaster diagnostics or something similar.
Dec 11, 2014 #7 T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Messages 14,013 The pedal is hard because the Powermaster isn't running. Got to figure out why first (BTW, DON'T drive). Find the brake fuse and check it. It's a 30 amp fuse labeled PWR BRK.
Dec 23, 2014 #8 Tori Active Member Joined Nov 4, 2013 Messages 524 or the accumulator ball isn't holding it's charge. mine did the same thing. no brake warning light either. pump motor worked. I ended up converting it to vacuum brakes. research vacuum brakes or hydro boost brake conversion for your other options to repairing your brakes.
