hard lines off vac. block???
grocerygetter
the back two, pcv and map lines...suck. LOL. I was pulling the plenum to install a rjc pp and the hard line going to the map (which is where my boost gauge is tied in also) cracked. So, I figure I'll eliminate it with a dremel and leave the hard line for the pcv. BUT...here's my question...there are obvious brackets that tie the two hard tubes together...those can be cut I know...but there is a little piece of material connecting them that looks like a 1/16th of an inch tube. I figure it's a casting flaw...right? Just cut it? there shouldn't be a vac. link between those two tubes other than at the vac. block, correct?
