tim sewald
- Oct 4, 2004
Hello All,
Needing help with diagnosing my hard to start 84 T-type. Since this hard starting has begun, I noticed the fuel pump does not kick on when I hit the key as it usually does. I checked pressure and with the key on it shows no pressure but running it's about 30psi. Thinking the fuel pump was bad, I put in a new AC Delco pump and sock. Same problem. Replaced fuel relay. Same problem. Are there any other factors in the equation? Any thoughts?
Tim
Tim
