Hartline hoods?
6togo
I know a bunch of guys run Cal's hoods how are the fit and finish i dont have my car together to test fit it before painting and wondering if that will be a problem? Does the hood require latches or with the stocker work and i think he has light weight shcks for the hinges correct?
You will need to install the safety catch. For 150mph+, Cal recommends hood pins. I am using Aerocatch latches. The hood fits great. Minor fender adjustments to make the gaps right, but if the car is apart, you will be adjusting during assembly anyway.
No issues with aligning things its all at the paint shop so all that needs done anyways just wanted to be sure the hood did not need any trimming! I'm chatting with Cal about them hopefully shipping is not to bad!
