Has anyone ever used 5 star shine car wax on their turbo buicks?
evil666
I 've been reading about this 5 star shine wax that sounds interesting, but don't know of anyone that has used it. If anyone on this board has used it, please let me know your opions about it?
Thnaks,
Marco.
T-Top 86 Grand National (61400km)
stock long block, stock suspension, 12 inch red stripe convertor (2800stall), te44, smc alk injection (95 % etanol), 25.5lbs boost,( boost spike 28 psi in 1st gear), 94 octane, hooker cat back with dyno max ultra flow muffers, 42 ½ lbs 009 injectors, turbotweak alky chip with 23/21 timing, thdp, mease 24 row IC, Ron Custom max boost brake module, MT drag radials (275/50/15) 3720lbs race weight with driver. (Torque convertor locked only after car shifted in third), rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, comp cam 980 valve springs. Weld Drag Lites with skinnies up front, electric exhaust cut-out.
BEST E/T
60FT=1.53
1/8= 7.25
1/4= 11.48
MPH=120.82
BEST 60FT=1.52
Have not used the product of your inquiry, but if
there is ever a product to remove or even "hide"
the water spots, leaf spots, acid-rain spots, etc. <----------:eek: :eek:
on the sub-standard factory paint, they'll get my $$.
Looked it up at www . 5starshine . com.
Reads interesting. Re-post on it if you try it..
Probably the only "cure" for the factory paint: $4-5K paint job.
