SignUp Now!Thanks Scott, I love the way it looks, and what a noticeable difference in weight.. Everyone said you were the guy to call when it was time to buy
Well now I can tell I have been looking at this computer screen WAY too long doing this write up.... LOL I miss understood you but the Instructions Do tell you to drill the front upper shock mount hole out to 3/4". This is only for the lower Delrin ball sleeve to fit into the 3/4" hole. I got confused cause the upper shock mounting shaft Will fit without drilling... Geeze time for bed..I swear that when I talked to ride tech they had told me that you need to drill the frame in the front. But I wasn't positive. My bad. Hope to be doing this set up within the next year my self.
Al,Well ok Scott I trust you, I just took the tires off and put the car up on stands all ready for tomorrow... This is really going to be funny, I am going to take pictures step by step if any one is interested?? AL
On the RT lower shock bracket, once you have the shocks off you need to take the lower shock mounting stud off where the old factory shock went to, once that is off then you will need to take the bottom bolt out of that lower control arm that is right there, then the RT lower shock bracket will go on (you should see where it will mount up now), put the lower control arm bolt back in, then silde one of the supplied bolts from the RT rear shock kit into the hole where the old factory lower shock stud was, tighten everything up real good and your lower coil over brackets are installed.Well ok it is almost a week and I have tried to do this upgrade by myself.... In a weeks time I have taken the shocks off, and that took about 20hrs... I Can Not for the life of me get the stock springs off.... The car is stock and has a stock sway bar, so I figure why take off the sway bar, I will just remove the lower arms... I didn't know you needed to support the Rear or it will turn and yank off the Drive shaft. I am completely over my head and know it... I also dnt see how that bottom bracket (Ridetech) for new shock fits in I tried for many hrs.... just an update maybe a little Help
Scott, I think I have the wrong brackets that hold the rear shocks to the bottom of the axel?? the pic in the packet dsnt look like what I have.... I have a big tail piesce on mine?????
