My 87 GN has been sitting for nearly 2 years. Tried to fire it up the other day and refuses to start. Here is the rundown:
I have injector pulse
Fuel Pressure is 40 psi
Check Engine Light comes on with key in "on" position
No error codes
CCCI fuse is good
I have 12 volts at terminal M of the Ignition Module connector
Igniton Module was replaced 3 years ago with a unit from Advance Auto
I followed the No Start Tree and this leads me to believe the ignition module is faulty. Before ordering an ignition module, is there anything else I should try?
No error codes
CCCI fuse is good
