- May 26, 2001
I just had a customer with similar issues as yours.
He bought the new replacement Y fitting with hoses pre-installed from a reputable vendor. Upon further investigation it was found that his new Grey Y fitting had the restricter in the wrong leg from GM, when compared to his old Grey Y fitting.
If you still have your factory Grey Y fitting, look and see if the restrictor in it, is in a different leg than the new one you just received. If it is, it's a simple matter of using your old Grey Y. If they are identical, than I would suspect, as others have said, that there is an issue with your puck and or wastegate actuator.
I can tell you, it is very hard, almost impossible, for a heavy duty actuator to run boost lower than 18psi with nothing being done to the wastegate hole in the turbine housing. Especially down to 5-7psi. The spring rate on our heavy duty actuators starts at 18psi.
My bet is, it's the new replacement Grey Y fitting you just installed.
Let us know what you find.
Patrick
Patrick
