Having trouble starting
84GNv6
Buddy of mine is having trouble starting his gn. He doesn't have a profile so I'm posting for him. Here's what I know...Compression is 140, fuel pressure only 6-8 psi, plugs are getting spark, and brand new fuel filter. Any insight is appreciated. If more info is needed on car...let me know. Thanx
More Info on Steve Wood's site: http://www.vortexbuicks-etc.com/no_start_tree.htm
I'd start with that fuel pressure reading, thats way too low how many volts at the pump?
If you are truely getting only 6 to 8 psi fuel pressure then you have a fuel problem
Items to start with, power to fuel pump, fuel filter, regulator, fuel pump empty tank bad fuel.
I would attach another FP gauge just to verify but if it is that low there is your issue
fp should be 38 to 42 psi for a stock setup
He's going to check the fuel filter to see if it's clogged. Car has been sitting for 6 years.
Uh...that'll do it.
I assume all fuel has been drained out and it has a fresh battery?
currently cutting it the F loose
