Yankee John
- Sep 17, 2008
I bought hardened, thicker rocker shafts from a vendor in June and installed them a few weeks ago (along with some Champion iron heads, TA 49 turbo, etc...) After driving it for a day, I started getting noise from the top of the motor. At first I thought it was lifter noise. The noise kept getting progressively worse, and then I finally stopped driving the car it got so bad. I have a total of 390 miles on the car since I put it back together.
Thinking that it was the lifters, I pulled off the intake manifold and valve covers, Preparing to change out the lifters. I take off the rockers/shafts, and this is what I find- The hd shafts are very deeply grooved!
Here is what I did when I installed them; Re-used the stock rockers, pushrods, and shaft bolts (torqued to 25 ft/lbs with blue Loctite). I also liberally lubed up the shafts and rockers with moly cam/assembly lube. I cleaned all of the pushrods and made sure that the oil channels were not blocked up (the pushrods went back into their original possitions also, along with the rocker arms).
I believe that the Champion heads have the standard 100 lb valve springs that they normally come with (heads bought lightly used from a board member here).
Does anyone here have an idea of what happened? All of the rockers galled on the shaft, some positions much worse than others. Needless to say that I'm going to need new rockers now to, at the very least.
I've called the vendor and am sending them the pics also- Hopefully they can help me out a little bit here (I've spent a lot of $$$ with them in the last 2 years).
Thanks for any input or advice that you can give me on this!
John
John
