Yankee John
- Sep 17, 2008
Are the pushrods clean inside?
Yes, When I assembled it the first time I made sure that the pushrods were clean and not restricted.
SignUp Now!Are the pushrods clean inside?
Lack of lube is definitely a possibility, but I think it would likely show some blueing (heat damage) on the rocker shafts themselves where the wear is severe. In these pics the shafts look like they have been running relatively cool.
Thanks Rick. I had just installed an oil pressure sending unit when I put the heads/turbo on, but had not hooked up the gauge yet I can tell you that the oil "idiot light" never blinked or came on.
Does the oil light come on with "key on, engine off"?
Yes, But it goes out after the engine started.
John
John,
When you put the oil sender in for the gauge, did you remove the factory sender?
Sorry to ask but do you know how to prime your oil system and did you do so after the motor work?
Any other damage found yet?
My asst manager is taking the shafts up to MN State University Mankato today and hardness testing them in the engineering lab (He's an AET student there). At least we will know if soft shafts were a contributing factor to my oiling problems.
John
P.S. No other damage found- yet. I haven't been out working on the car since I took the shafts off the other day.
I'm just so frustrated after doing all that work for nothing, it seems......
John
John
Rick, I put a "t" on the original oil sender/turbo feed block for the oil psi gauge sender.
I must confess- I didn't prime the engine after the work I did. It was only down for a couple weeks- I didn't think that I needed to. I don't know how to do it on a Buick- Is the procedure similar to a SB Chevy?
John
Any updates?
