SignUp Now!I have a set of springs from Kirbans. I believe they are 100lb springs. Look at my last post again I edited it a little. Yeah it seems like right now under full throttle the car holds steady around 4600-4700rpms. does that seem normal?Quiky One said:Yes, I would put 100lb. valve springs on. Lets, you run up to 5200 rpms without valves "floating". After 17 years they arent as strong as they were when new. I believe you should get the 100lb. springs from a 1970 Camaro LT1 motor. I dont know what others use.
Jason
dvernst said:That's funny I just got done waxing my antenna J/K How about valve springs? It should be o.k. if I change those right? If I do change them should I do valve seals also? I saw in your other post you stated factory head gaskets can hold up to 30 psi boost? So on my car if everything is tuned right I could run 25-26 psi and the head gaskets shoukd be o.k.? Thanks
