SignUp Now!Witch head gasket are the best to use? Build is in sig. Basically it a DD but want to turn up the boost to 25 and do some track some.
Shaun
I've been running my stock HGs for 65k miles now and would recommend using the same for replacement unless you are POSITIVE your heads and deck are PERFECTLY flat.
I hope they are because the motor is still at the machine shop. LOL
I have bigger problems if there not. LOL
Shaun
If it's at the machine shop then o-ring the block with stocks HGs and you'll be good to go.
Here is my 2 cents prep is what makes all the diffrence no matter what the gasket! I have tried them all and i really like the Comectics with studs! the block should be checked with a straight edge and perfectley straight same with heads next clean all bolts holes with thread chaser not a tap this crucial clean all holes with crc eletro-motive cleaner run studs in finger tight then 1/4 turn with a 1/4 ratchet make sure all studs are equall in height with a straight edge if all studs are sitting right coat the lower studs exhaust side with permatex liuqud thread sealant and intake studs with arp molly lube! next rough both block and heads with emery cloth the trick is you want the gasket to grip if the surface is to smooth it wont! Next using indian head liquid about 2 bucks a bottle 2 bottles will cover you hit both sides of gaket on work bench on a piece of card board Cometic says to but on dry I disagree I dont like silicone cause it has the nature of squezzing out and plugging water ports!! Guys restoring P51 mustang Engines use it so you know it works! Next slide heads on and use molly lube on studs and washers both sides dont be bashfull!! Next torque to 75 foot pounds in three steps! Next using a heat gun heat head up going back and fourth like you were painting a wall usually ten minutes then retorque to 75 foot pounds!!!! I am not a professional engine builder but I work on cars for a living ans was taught do it once do it right!! If any body has any thing to add or has comment please let me know my ego trip died many blown head gaskets ago![]()
