Apr 19, 2011 #1 B bobbybike New Member Joined Jan 29, 2010 Messages 44 what head gasket can i run in my 3.8 30 over ,im runing fel-pro 8723pt1 and not happy with them . can you help .
Apr 19, 2011 #2 S skidman 3 turbos,no money Joined Aug 16, 2010 Messages 138 Head gasket I use stock style/Victor head gaskets in my 81 Riv. draw thru engine. Have ran as high as 19 PSI with 110 octane gas,lifting before third gear to avoid any possible detonation. Mark.
Apr 22, 2011 #3 WarWagon Caustic Cacophony Joined Mar 10, 2007 Messages 2,329 fel-pro 9441pt Use those^
Apr 24, 2011 #4 B bobbybike New Member Joined Jan 29, 2010 Messages 44 i only have an 8 bolt head will this still work ? and for bore size 30 over ?thanks for the help .
Apr 24, 2011 #5 B bobbybike New Member Joined Jan 29, 2010 Messages 44 can someone shed some light on this. thanks
Apr 24, 2011 #7 B bobbybike New Member Joined Jan 29, 2010 Messages 44 thanks ,what do you think about the torque specks ?
Apr 24, 2011 #8 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 Which bolts/studs are you using?
Apr 24, 2011 #9 B bobbybike New Member Joined Jan 29, 2010 Messages 44 head gasket I have arp bolts . thinking of going to torque yield bolt
