head gaskets?
GN73
any advice appreciated what head gaskets should i use m&a heads and a 109 block thanks
The ONLY down side to the Fel-Pro 9441-pt head gaskets is that if you pop one, you also need to pull the oil pan and clean out the oil pump pick-up screen. If you want the best the Cometics are hard to beat. BUT you MUST have the proper finish on the block and head surfaces. Stock machining on the block deck is too course.
our head gaskets work very very good. cometics work very well at sealing combustion but have a tenancy to leak oil, also if the heads do lift the thin outer layers tend to act as an igniter for the combustion gases and sometimes cause the head to erode material from the sealing surface.
our gaskets of cours do not have any of these issues and work very well.
take a look
RJC Head Gasket Kit
