gnxjames548
- Sep 27, 2007
Blew head gasket again this time at 29 psi Boost. Could i get some feed back about what head gasket to use this time.
SignUp Now!Blew head gasket again this time at 29 psi Boost. Could i get some feed back about what head gasket to use this time.
LOL That's what i don't want to do is Blow the bottom end out.
I'd stay with stock type to act like a fuse.. Lot cheaper and easier to do. Do you know why it detonated ??
I went from 25psi. to 29psi. and I forgot to add fuel through the chip. **** Happens
The Victor Reinze from Napa are same as stock & hold up well.
How much fuel were you running?
whats the part#?The Victor Reinze from Napa are same as stock & hold up well.
I have the 60lbs. Injectors. Hot wired 340 but i run straight C16Fuel pressure is 71 psi for 28 lbs of boost....if thats what you're asking. This is with 60 lb injectors, hotwired 340 pump, and single nozzle alky.
