Cometic is making head gaskets for the stage motors in various thicknesses. They will also provide a custom ring size if required. Pricing is about $100 per side and the gaskets are reuasable if you replace the two outer .010" steel sections (it is a 3 piece gasket with most of the cost tied up in the inner aluminumized steel section).
Also they can make custom intake gaskets if they are sent the pattern of the ports. Cost is about $10 per side. Contact Jason Moses at 1-440-354-0777
http://www.cometic.com/home/home.htm
Jeff
Jeff
