SignUp Now!OK thanks guys will check into all your advice.The parking lights work but the head lights won't come on. Bad switch? If so how hard is it to replace.
yes thats the dimmer that usually burns up
Wait. I'm confused.That's the dimmer switch that's gone bad on me a couple of times. I've always gotten it from the local parts store.
Why didn't anyone tell me I was so stupid. Or maybe they did. And maybe I'm just stupid.the on/ off dash switch has a built in thermal shutoff , if you overload it with higher output bulbs it will flip off , once it cools it returns to normal operation .
the one you swapped out Joey normally would have worked again after it cooled down
Sorry for the confusion. I'm talking about the high/low beam switch on top of the steering column.Wait. I'm confused.
The one I described, or the one Paul (pacecarta) is talking about?
