calais1965
- Mar 10, 2009
Is there any torque value for tightening header bolts to champion aluminium heads?
SignUp Now!calais1965 said:Bolts came with my headers. I should order studs for these, do you use locktite for studs?
calais1965 said:There is helicoils in the threads.
coach said:Not on my GN1's. I asked 2 members here about it, and my builder. All said they use studs. I may install coils before it put in the car.
The rocker shaft holes are coiled. That's it.
jpwalt1987 said:Coach, make sure the rocker shaft holes have a long enough insert. Somehow mine had a short 3/8 long helicoil in it. The pedestal snapped.
Ok!
Have to order studs, because i live in finland 3/8 studs are not common in hardware store ( i own hardware store ) ....
i think they are 5/16"..
Nick Micale said:Sorry but Buick turbo heads iron and alum use 3/8" header bolts.
pacecarta said:the studs from arp are nice .
3/8-16 for going into the head.. 3/8-24 fine thread for the 12pt nut
only complaint is the rounded stud end prevents removal install with header in place
what i do is slot the end with a whizzer wheel so i can use a flatblade screwdriver
