header cracks
  • Thread starter Thread starter The Boost Creep
  • Start date Start date
T
The Boost Creep
Guest
i hear more about the driver side between #'s 3 and 5. Mine has a HUGE crack about halfway around the passenger between 2 and 4. I have my adjustable wastegate rod turned all the way in and can only get 12#'s of boost. How can i tell if the drivers side is bad too, i cant see because of the heat shields. :confused:
I could hear and see the one on my car, heat shields or not...
If the passenger side is cracked is probably safe to assume the drivers side is too. Once you remove the crossover to have the passenger side fixed the drivers side is a cinch to remove, might as well check it.
Jeff
when i jacked up my car and looked through the wheel well i could clearly see the cracked driver side header.:)
